Автор Тема: Дисплей-индикатор в кнопке tpms давления шин  (Прочитано 690 раз)
AleXL7
  • дизельный
  • Трахтор
    • TLС150 3D
Новый в упаковке для автомобилей Toyota, Lexus под заглушку размер 22x33mm работает с оригинальными датчиками с 2015 года. цена 6т. руб, отправлю ДЛ по России.
W417-T is developed for Toyota and Lexus blank switch type TPMS.
W417-T was developed for Toyota which can 100% fit into blank switch space inside the vehicle.
(Size 22mm x 33mm) and displaying through OLED monitor to make driver able to acknowledged all tire information and able to react instantly when abnormal status happened.
PRODUCT FEATURES
Controller type, use for specified vehicle.
Multi tire change mode, easy setting.
Tire temperature and pressure information display.
Four tires information simultaneous display.
It would also warm if the tire flat quickly.
When the tire pressure <20% standard pressure or >30% standard pressure,
it will alert with sound and words at the same time.
OLED touch panel, one button can set all functions.
SIZE FOR PLUG IN22mm x 33mm
TRANSMITTER MODULE SPECIFICATION
Power Supply: 3V Lithium battery
Operating Humidity: Max 95%
Storage Temperature: -40°C ~ 125°C
Operation Temperature: -30°C ~ 115°C
Transmitting Power: Max 72 dBμv/m
Transmitting Frequency: 433 MHz
Pressure Monitoring Range: 0 ~ 116 psi (or 0 ~ 800 kPa or 0 ~ 8 bar)
Pressure Reading Accuracy: ± 1 psi (or ± 7 kPa ; ± 0.1 bar)
Temperature Monitoring Range: -30°C ~ 115°C
Temperature Reading Accuracy: ± 3°C
Module Weight: 22.7g ± 1g
RECEIVER MODULE SPECIFICATION
Power Supply: DC 9V ~ 16V
Operating Humidity: Max 95%Operation Current: ≦ 80mA at DC 12V
Storage Temperature: -30°C ~ 85°C
Operation Temperature: -25°C ~ 85°C
Pressure Display Range: 0 ~ 116 psi (or 0 ~ 800 kPa or 0 ~ 8 bar)
Temperature Display Range: -30°C ~ 115°C
"Время - деньги". Деньги - это временно...
AleXL7
  • дизельный
  • Трахтор
    • TLС150 3D
AleXL7
  • дизельный
  • Трахтор
    • TLС150 3D
